Home › Forums › Products › Plug-Ins › Blackhole demo no presets › Reply To: Blackhole demo no presets
December 13, 2022 at 5:13 pm
#167689
Below are some general troubleshooting steps that should resolve your issue:
Windows:
- Eventide plug-ins use a custom preset bar in the plug-in GUI, make sure you are looking there rather than the DAW’s preset bar.
- If you are looking in the correct location in the UI, and still do not see any presets, then check that the presets are installed in the following location: c:\Users\<user name>\My Documents\Eventide\<plugin name>\Presets
- If the presets are not there, then you should uninstall and reinstall the plug-in, making sure the “Documentation and Presets” box is checked during the installation process.Uninstallers are located at Start Menu->Control Panel->Programs and Features->Uninstall a Program.
Mac:
- If you are looking in the correct location in the UI, and still do not see any presets, then check that the presets are installed in the following location: ~/Music/Eventide/<Plugin Name>/ (whole folder)
- If the presets are not there, then you should uninstall and reinstall the plug-in, making sure the “Documentation and Presets” box is checked during the installation process.Uninstallers are located at Applications/Eventide/Uninstallers/.
If the presets are still not showing up after completing all of the above steps, I can send you the presets to manually place in the correct folder.
