Home Forums Products Stompboxes H90 with Behringer FCB1010 Reply To: H90 with Behringer FCB1010
#167692
personalitytypeo
    Just wanted to report back that I’ve turned off omni and continued testing the load speed with various programs, and I think the main issue is the H910 H949 algorithm. It seems to take a much longer time to load, which is a huge disappointment because the harmony effects are what I was most excited for. And it doesn’t matter if it is set to modern or H910. The only time an immediate switch to a new program occurs is when I switch to a blank preset in my playlist. Is it just me, or has anyone else noticed this? Again, I’m coming from using a Pitchfactor that works perfectly with the FCB1010 and loads presets immediately. Is that going to be possible with the H90, or did I make an investment in the wrong pedal?
