Home Forums Products Stompboxes h90 output Global volume range Reply To: h90 output Global volume range
#167719
siggy76
    I use the eventide in a rack and I command it via midi. It’s the last in my signal chain.
    I would like to have a master volume control mapped to a CC where I could vary  the volume from -10db to 0db using a pedal linked to my midi controller.
    This is possible if I map the output of the B algo but there’s no way to limit the range in the global section.
