It seems to me a bug that there is no global output volume range limit as in the single preset/algo when mapped to a CC…could you please implement a range limit also in the global midi assignement?
I use the eventide in a rack and I command it via midi. It’s the last in my signal chain. I would like to have a master volume control mapped to a CC where I could vary the volume from -10db to 0db using a pedal linked to my midi controller. This is possible if I map the output of the B algo but there’s no way to limit the range in the global section.
