Home › Forums › Products › Stompboxes › Using H9 in and out of fx loop ? › Reply To: Using H9 in and out of fx loop ?
December 19, 2022 at 11:42 am
#167836
If you have both input and output jacks connected on the H9, the H9 will always be used in a stereo operation. If you are only processing on input/output 1, you’ll be missing the other half of the stereo image.
The H90 can achieve a mono path for the Pre path and a stereo path for the Post path, but the H9 is not as flexible for this sort of thing.
