Home › Forums › Products › Stompboxes › H90, amp, and Strymon Iridium › Reply To: H90, amp, and Strymon Iridium
December 20, 2022 at 2:02 pm
#167859
Yes, however, the H90 only allows either two mono inserts or one stereo insert. So, as it pertains to this setup, you will not be able to do everything you want to do with a stereo insert. Regardless, there is no reason to need a stereo signal from the Iridium if even the Iridium doesn’t allow you to have disparity between left and right, that is, unless you’re using different IRs for left and right.
