Home › Forums › Products › Stompboxes › Delay controlling Eventide H9 with midi expression pedal › Reply To: Delay controlling Eventide H9 with midi expression pedal
December 21, 2022 at 7:07 pm
#167885
Hello Urantia76, if I understand correctly, for the problematic presets, you are sending multiple CC#s to change parameters. I don’t know what’s causing the delay but to try and solve it, have you tried mapping your expression ranges for all the parameters to the ribbon controller of the Harmadillo algorithm and then send only one CC# mapped to “Set to expression pedal” to control all the ranges simultaneously?
