Home Forums Products Stompboxes MIDI CC number Reply To: MIDI CC number
#168024
RikjCarty
    Just wanted to add… All MIDI devices should be assigned a unique CH number, unless your intention is to set all devices to OMNI mode.
    To best specify the device you want to command via MIDI, it’s best to map each to a CH numb.
    So…
    Set MIDI from control/Pedal to transmit on CH 2… Set H90 to receive on CH2.
    PC = Select Program within a UserBank (You’ve got to pre-select the User Bank right now).
    CC – Continuous Control (Gain, FX Levels, Times, etc.) Set on each control in a Preset/Algorithm Use to OUTER RING (in Control SW) on EACH CONTROL to set the MiDI CC value RANGE. So you can set a MIN or MAX value using the outer ring and just send CC value of 0 or 127. If you set the OUTER RING to FULL Min/Max… you can increment or decrement any control to accurate value… with MID range being CC value 64.
    Unfortunately, I’m still waiting for the method to change UserBanks via MIDI control.
    Best!
