Home › Forums › Products › Rackmount › Just got the H9000, what, if any, of my FX should I even keep? › Reply To: Just got the H9000, what, if any, of my FX should I even keep?
January 4, 2023 at 4:00 pm
#168241
You can set up the Fractal 4CM and go both in front of the amp as well as in the loop. You ultimately should set up both the AxeFX and H9000 this way. There is certainly enough IO to do it.
