Home › Forums › Products › Stompboxes › manual for H90 control? › Reply To: manual for H90 control?
January 4, 2023 at 4:40 pm
#168244
Sure thing. Performance parameters are functions that you would trigger using the P/A/B footswitches in perform mode. For example, this could be Program bypass or tap tempo, or a preset specific parameter such as the Looper’s transport controls.
The Performance Parameter Mapping tab allows you to map these parameters to external controllers like an aux switch or MIDI controller. This is useful if you’d like to use the onboard footswitches for active/bypass, and another controller for the preset specific parameters.
Let me know if you have any other questions.
