Home › Forums › Products › Rackmount › Just got the H9000, what, if any, of my FX should I even keep? › Reply To: Just got the H9000, what, if any, of my FX should I even keep?
January 4, 2023 at 5:31 pm
#168250
You can set up the Fractal 4CM and go both in front of the amp as well as in the loop. You ultimately should set up both the AxeFX and H9000 this way. There is certainly enough IO to do it.
Right good point. What a rat’s nest sheesh ok I see where I’m starting to get to though and it could be interesting. Now about that SY-1000 lmfao.
