Home › Forums › Products › Stompboxes › H9 MIDI transmit CC messages not working › Reply To: H9 MIDI transmit CC messages not working
January 6, 2023 at 3:35 pm
#168315
When you select PDL on the H9, you are selecting the control source (the expression pedal). You then need to select the destination (a MIDI CC#).
The CC# that the H9 transmits needs to control the parameter on the receiving device, it’s not clear if you have configured the correct CC# to control the parameters of the Nemesis or Ottobit. It looks like CC #4 is the expression pedal value for the Ottobit.
