Home Forums Products Stompboxes Rose – external controller advice Reply To: Rose – external controller advice
#168655
nohjnilknarf
    Thanks for the response.
    A few questions ……
    As the disaster area has trs midi out, can that not be used to connect straight to Rose trs midi input without an adapter?
    Secondly, when a midi controller is receiving expression control from an external expression pedal and then passing that on to Rose, does the expression pedal automatically map to ‘morph A/B’ as an expression pedal would if connected straight into Rose?
    Thirdly, are there any midi controllers that can connect to the USB input on Rose that can be recommended?
    Thanks
