Home › Forums › Products › Stompboxes › H90 – using unbalanced I/O with balanced load box/amp sim › Reply To: H90 – using unbalanced I/O with balanced load box/amp sim
January 31, 2023 at 9:36 am
#168765
You can use either an XLR to TS cable, or an XLR to TRS cable and you will be fine. The H90 has unbalanced inputs, but will accept a balanced TRS cable without issues. Just make sure you configure the H90’s inputs to line level.
