Home › Forums › Products › Stompboxes › Request – H90 inserts always on (whilst turning program off) › Reply To: Request – H90 inserts always on (whilst turning program off)
#168796
kevo888
    My main reason for asking for this feature is because I run a wet/dry rig. The insert is feeding the dry amp…no return to H90…out only.
    The dry and wet amps are on all the time. At the moment, turning a program off also turns the insert off…killing the dry amp and leaving the wet amp on.
    Wet/dry/wet would also suffer the same problem.
    I assume it is possible to do as in Perform mode..killing side A and B leaves the insert active. But that us too much tap dancing for me.
