Reply To: H9k forgetting Emote plugin setting
Home Forums Products Rackmount H9k forgetting Emote plugin setting Reply To: H9k forgetting Emote plugin setting
#168828
Are you using auto-connect? I have found that this issue is usually due to auto-connect being on. What happens is you open the DAW project, Emote connects to the H9000 in about 5 seconds, and the state restore pop-up does not come up when you open the plug-in window after the connection has been made.
You can either open the plug-in window very quickly when you open the DAW project (not recommended) or you can turn auto-connect off. When you do this, you should first open Emote every time you open a new DAW project, then connect to the H9000, and you should reliably be able to use the state restore pop-up. I’ve been using the H9000 with multiple DAW projects recently and this has worked fine for me once I turned auto-connect off.
I understand that this is not the best workflow and we do hope to improve this, but I cannot provide a timeline for when this will be addressed.
Please try my suggestions above and let me know if that works.
