Home › Forums › Products › Stompboxes › H90 Starting programs at zero › Reply To: H90 Starting programs at zero
#168842
joecozzi
    Hi guitarplyr, the Ground Control Pro should be set to “starts at 01” as the H90 does not make use of the MIDI standard of using PC#0 as preset 1. According to what you describe, it takes footswitch #3 to activate preset1, which does not make sense to me. Is it possible the Ground Control Pro buttons have custom programming other than the factory settings?
