Home Forums Products Stompboxes Help – H90 Pitchflex sweeping in semitones Reply To: Help – H90 Pitchflex sweeping in semitones
#168880
joecozzi
    On the Pitchflex algorithm, go to PARAMETERS and assign the Manual parameter to your expression pedal by pressing and holding the Quick Knob right under it. Make sure you assign the EXP input that corresponds to your expression pedal. If you need to, on the next page you can adjust the range of expression. Now your pedal will smoothly shift from one pitch to the other based on your algorithm settings.
