Home Forums Products Stompboxes Integrating H90 with Quad Cortex? Reply To: Integrating H90 with Quad Cortex?
#168953
jhilleary
    Yes, both of your statements are correct! If you don’t care about stereo, then Preset 1 on the H90 can be in Loop 1 of the QC and Preset 2 can be Loop 2 of the QC, then you can move each loop where you want it on your QC flow! This will work in both Dual Mode and Insert Mode – you just need to ensure you’re using the correct I/Os on the H90 depending on which one you choose. Insert mode is interesting of you have other pedals you’d also like to piggy-back on the H90 and bring into the QC – and you can also control where in the H90 signal flow they’re placed (before or after Preset 1 and/or 2).
