Home Forums Products Stompboxes Insert Mode Lists vs. Dual mode Lists. Reply To: Insert Mode Lists vs. Dual mode Lists.
#169068
joecozzi
    Hello jlane0710,
    I assume that all of the Factory Programs are available in either list
    Correct.
    If they are already incorporated into a Dual Mode List, I was wondering if they are just all on Path 1 or Path 2, or does it depend on the algorithms used (i.e. delays/reverbs on path 2 and wah/crush on Path 1)?
    They are all on Path 1. If the Programs were in parallel routing in the Insert Mode version, they will also appear in parallel in the Dual Mode list but in parallel on Path 1.
