Home › Forums › Products › Stompboxes › using foot controller with h90 › Reply To: using foot controller with h90
February 14, 2023 at 3:44 pm
#169106
In your screenshot, you have Aux Switch #2 assigned to Program > Byp/Act, so that would make Footswitch #2 bypass or activate the Program. You will need to delete this mapping by setting the Control Source to “Off”.
In the Performance Parameter Mapping page, try the following:
Switch: P
Parameter: HotSwitch 1
Control Source: Aux > Switch #1
This will map HotSwitch 1 to Aux Switch #1.
If you’d always like your Aux Switches to control the 3 HotSwitches, this can be done using Global Mappings. These mappings are configured under System > External Control.
https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/appendix/global.html
