Home Forums Products Stompboxes Another routing question (with line mixer) Reply To: Another routing question (with line mixer)
#169141
Tokyo tapes
    Yes, the first algorithm is before the mixer in Scenario A and I’m not planning to use the second insert in any of the scenarios.
    I have no troubles having the signal converted once the H90 is in the mixer loop but the signal going to the mixer input from Out 3 is the dry signal from the guitar in Scenario B so I don’t want any conversions and as little coloration as possible.
    So both scenarios is possible with no recabling, only internal patching in the H90?
    Another question: In scenario A, Is it possible to have the first algorithm with a regular internal mix of wet/dry while the second algorithm is set on Kill Dry, due to it being in the mixer loop?
