Home › Forums › Products › Stompboxes › Another routing question (with line mixer) › Reply To: Another routing question (with line mixer)
#169142
joecozzi
    I have no troubles having the signal converted once the H90 is in the mixer loop but the signal going to the mixer input from Out 3 is the dry signal from the guitar in Scenario B so I don’t want any conversions and as little coloration as possible.
    So that it’s clear, the moment you connect a guitar to Input 1 of H90, the signal gets converted A/D while the H90 Program is active; the signal gets sent directly to Out 3, where it’s converted D/A on its way to the Parallelizer.
    So both scenarios is possible with no recabling, only internal patching in the H90?
    Yes.
    Another question: In scenario A, Is it possible to have the first algorithm with a regular internal mix of wet/dry while the second algorithm is set on Kill Dry, due to it being in the mixer loop?
    Yes.
