Home Forums Products Stompboxes H90 using a switcher Reply To: H90 using a switcher
#169387
crustofsin
    one more question cause i cant find the answer about it:
    i ve got a marshal jvm410jhs (the satriani version) which has midi
    this amp has 4 channels and within each channel there are 3 more channels…
    therefore it has 12 channels
    will i be able to switch to all of those with the looper through midi function
    is ur looper or the mkvi able to select 12 different amp channels or is there a restriction to the number of the channels for the amp ?
