Home › Forums › Products › Stompboxes › Expression Pedal › Reply To: Expression Pedal
        February 24, 2023 at 11:47 am
        #169396
No matter what I map to the expression pedal it’s always controlling volume like a swell.
Does this happen for every Program? If so, the expression pedal could be mapped to the global “P In Gain” parameter. Check Global – Pedal Ctl to see if the expression pedal is mapped to anything.
- Press PROGRAMS & ROUTING until you enter the System Menu.
 - Select Global and navigate to the third page of controls.
 - Once you’re in Global – Pedal Ctl, use the first quick knob to scroll through all the mappable parameters ensuring nothing is mapped to the expression pedal on the input you connected to.
