Home Forums Products Stompboxes H90 Power draw & routing Reply To: H90 Power draw & routing
#169534
joecozzi
    No, That’s not enough power as the 12V outlet of the Ojai R30 only puts out 375mA. You could use either two 9V outlets with a current doubling cable and a polarity converter cable with a 2.5mm barrel on the H90 side, or you can use two 12V outlets with the same cables.
