Reply To: EXP pedal adjustments
Home Forums Products Stompboxes EXP pedal adjustments Reply To: EXP pedal adjustments
#169577
cjcampbell2000
Hi, it’s the ehx single one before that I used a line 6 one I believe I did calibrate both and saw it gave 100 percent. on the graphic and on the little bar that gives numbers. it works and I’m getting the full sweep, but it seems the pedal is only seen by h90 at about 30 percent of its travel from the heel position. it’s like the pedal has to much travel on the heel side of the sweep thanks
