Home Forums Products Stompboxes EXP pedal adjustments Reply To: EXP pedal adjustments
#169589
joecozzi
    the line 6 with ts cable jumps at the heel position to 100 percent and back to 0 by the time the pedal has traveled about a 5th from the heel position.
    I have the Line 6 EX-1 and it works as intended. What version of the H90 firmware do you have installed on the pedal?
