Home › Forums › Products › Stompboxes › H90 Inserts – I’m Using [Fill In The Blanks] › Reply To: H90 Inserts – I’m Using [Fill In The Blanks]
#169596
    I stumbled onto this one backwards.  Not using your physical Insert routings / jacks for anything?  Looking for a super long delayed effect?
    Select an INIT Program (blank THRU/THRU).
    • Load up a delay [UltraTap] in Preset (A).
    • Parameter Edit:  MIX = 100.  Length = 10.00s  Taps = 1
    • Load up another delay [Reverse] (or anything else) in Preset (B).
    • Parameter Edit:  Mix = 100.  Delay(s) = 3000 mS.
    Tap the Parameters LED button again for the (P) INIT Program page.
    • Parameter Edit:  Mix = 50
    Tap the Routing LED button.
    • Keep it in Insert Mode – Series.
    • Turn a couple clicks on Quick Knob 2 [Insert 1].
    • (1) should be in parallel (dotted line) with your two Presets (still in series).
    Dry input signal, as always.  10 seconds later, the reversed delay tail pops through.
    For extra credit:  Try looping the Looper.  CB Habit, I’m comin’ after ya’.
