Home Forums Products Stompboxes H90 Routing with Factor Series Reply To: H90 Routing with Factor Series
#169662
AntCece
    Update:
    actually it worked for a while, it just worked well with TF routed in mono H90 3d out > TF input etc…
    I’ve tried to connect MF in H90 4th Out and changing the h90’s  routing parameters   after a while feedback start to roar 😅 and I have to disconnect the cables because the hissing or feedback doesn’t stop when I tried to move the h90 routing parameters.
    It seems to work in this way:
    h90 3d output > MF Input//MF out to  TF In /// TF out to H90.
    to me this kind of issue seems an overload or something else dunno 🤷‍♂️
