Home Forums Products Stompboxes H90 Bugs Reply To: H90 Bugs
#169684
    I can reproduce your delay time issue using H90 Control, but if I use the quick knob on the pedal to adjust this I can get it to 610 ms. We plan on adding the ability to type in parameter values using H90 Control, but I cannot provide a timeline for this. For now, I would suggest using the quick knob if you need the 610 ms delay time.
    The PitchFlex manual shift parameter will always recall as if the parameter is at -1. If you save the Preset with the manual shift at +1 (or with your expression pedal at the toe position), the Preset will not sound like it is at the toe position until you adjust this parameter. I believe this behavior is carried over from the H9. If you save your Preset with the expression pedal at the heel position and the manual shift at -1, your presets should recall correctly.
