Home Forums Products Stompboxes H90 Tuner-How to set where it mutes Reply To: H90 Tuner-How to set where it mutes
#169765
rck
    Hi rck, This was not addressed in this update. We will respond here when this has been fixed.
    Thank you for that update.
    Heads up, I did recently also notice when activating the Tuner that the signal will be allowed to pass through and make sound even if a PROGRAM is activated but the Program Mix is less than 100%. You all may have thought of that, but wanted to make sure you knew of the behavior.
