Home Forums Products Stompboxes MIX Parameter on H90 Screen Reply To: MIX Parameter on H90 Screen
#169839
rck
    This is correct. If a parameter is assigned to a Quick Knob and also mapped an expression pedal, then you will see that parameter being adjusted from the UI when you move the expression pedal. Can you be more specific about your request? You would like there to be a larger indicator on the screen that shows the mix parameter value when being adjusted from an expression pedal?
    Yes, exactly: I would like there to be a larger indicator on the screen that shows the mix parameter value when being adjusted from an expression pedal. OR maybe whatever value is assigned to Quick Knob 1 or far left Quick Knob to be enlarged on the screen so that could variable and more beneficial.
    -thank you again!
