Home Forums Products Stompboxes MIX Parameter on H90 Screen Reply To: MIX Parameter on H90 Screen
#169840
    Thanks for clarifying.
    Do you always use the expression pedal for controlling the mix of a Preset? One way you could go about this would be mapping your expression pedal to the HotKnob, and then mapping the mix parameter to the HotKnob. Now, when you adjust the expression pedal, the HotKnob bar will indicate your mix level, which is a much larger display than the Quick Knob.
    You can also create a global mapping so the expression pedal always controls the HotKnob, and you’ll just need to map the mix parameters of your Programs to the HotKnob – https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/appendix/global.html
