Home › Forums › Products › Stompboxes › H90 Quick Knob Sensitivity › Reply To: H90 Quick Knob Sensitivity
March 28, 2023 at 10:11 am
#169946
The operation of the Speed parameter changes depending on the Resolution parameter. If you change the Resolution to “Chromatic” or “Smooth” the Speed parameter should adjust with smaller parameter changes. The other resolution settings are course controls and will require more turns to adjust the parameter. Let me know if that clears it up or if you are experiencing something different.
