Home Forums Products Stompboxes H90 Quick Knob Sensitivity Reply To: H90 Quick Knob Sensitivity
#169951
joecozzi
    Hi coirbidh_99,
    If you’re looking to go from one set of values to another instantly, the H90 gives you three hotswitches found in the Perform Mode. Each footswitch P, A, or B can be assigned the Hotswitch performance parameter.
    To Program hotswitch values, go into the PARAMETERS menu, press and hold either P, A, or B to enter hotswitch program mode. There you can use the quick knobs to assign the values each parameter will change to when the hotswitch is engaged.
