Home Forums Products Stompboxes H90 basic settup with small amp Reply To: H90 basic settup with small amp
#169969
joecozzi
    I power drives with a separate ps, and the original wall wart for h90. when I do this it disconnects from h90 control continuously, but when I use a battery in od pedal no problems.
    Let me see if I understand this correctly. The H90 is powered with supplied factory adapter and you use another power supply for the other pedals, correct?
