Home Forums Products Stompboxes Bypass via MIDI? (not toggle) Reply To: Bypass via MIDI? (not toggle)
#170058
Lorpal
    If your switcher is set to toggle – it will always turn it back on…
    if you’re using an Es-8 you could specify that it sends the 0 value in both states… in this case “on” will still equal off
    why would you hit the switch again if it’s already off?
