Home › Forums › Products › Stompboxes › Strymon Cloudburst ensemble effect on H90? › Reply To: Strymon Cloudburst ensemble effect on H90?
#170066
    Depends.  If those auto-responsive dynamics & continuous signal analysis are important to you, then maybe not.  You can easily simulate all of that with an expression pedal.  Any of the ‘huge’ reverbs will get you close.  Most, if not all H90 reverbs, feature gigantic decay times and Infinite / Freeze.
    I like using DynaVerb’s Omnipressor mode up front, for the slower attack.  And the H90 Shimmer algorithm doesn’t necessarily have to ‘shimmer’.
    Maybe this will give you a head start:
    https://patchstorage.com/fortissimo-crescendo/
    But again, experiment with all of the reverbs.  They all bring different flavors and a unique feature set to the table.  As one example, DualVerb.
