Home › Forums › Products › Stompboxes › H9 – restoring factory program? › Reply To: H9 – restoring factory program?
April 9, 2023 at 8:12 pm
#170330
Found it. A few ways to go:
- I use H9 Control on Android, so that does work.
- You can go to More … Import Preset in H9 Control under the Presets tab …
- … or you can drag ‘n’ drop it to the same spot.
https://www.dropbox.com/s/2nh5v87ke0bf4q4/CLOCKWORKS%20H9.tide?dl=0
If you rather rebuild it, just pick any UltraTap preset you don’t want, and save the changes when you’re done. It looks like the only expression pedal / ribbon mapping concerned is Length, from Whole Note to 2.5 Bar.
