Home › Forums › Products › Plug-Ins › How to record noise generator sounds in H3000 Factory? › Reply To: How to record noise generator sounds in H3000 Factory?
April 10, 2023 at 3:07 pm
#170355
Hi, I assume you are referring to the Noise and Function Generator modules in H3000 Factory? If so, these are intended as modulation / signal sources for the other modules in the Effects Block section, not for synthesis purposes.
