Home Forums Products Stompboxes H90 CC control request Reply To: H90 CC control request
#170446
Chevron
    Thank you, I know you can do this in the software, and you can also do it on the pedal in parameter edit.
    But to have full parameter control over any preset you load into side A or side B you need to assign 17 or so CCs for each of the 64 algorithms and save each one in a user bank (you would need to do this again with alternative cc numbers in case you load duplicates algorithms in side a and b)
    Having the option to assign them globally for side a and b, so I can control whatever algorithm is loaded, means I only have to assign 34 or so CC’s, instead of creating 2176 CCs and saving 128 algorithms!
    Even if you wanted to avoid this by just assigning them every time you need to, assigning controls every time slows down creativity/productivity, especially when a global option could avoid this.
