Home › Forums › Products › Stompboxes › Volume boost when activating H90 in effects loop of Quad Cortex › Reply To: Volume boost when activating H90 in effects loop of Quad Cortex
April 15, 2023 at 8:25 pm
#170481
If you are not running it parallel to your dry signal but in series on the quad core then it must be a send return level issue. If you just have just cables in and out and you use the loop does the level stay exactly the same when you turn it on and off?
