Home Forums Products Stompboxes H90 Inserts – I’m Using [Fill In The Blanks] Reply To: H90 Inserts – I’m Using [Fill In The Blanks]
#170586
Infection
    I have tried a few different setups.
    Wet/Dry/Wet direct from the H90 was fun and easy to setup with output 1/2 to the wet amps and output 3 to the dry amp.
    Same setup as above with a few drive pedals in a mono loop was pretty cool also, but i can never stop tweaking and reordering my gain pedals, so presets didn’t really work out that well in this setup for me.
    Wet/Dry TPS style was very cool, but i missed some stereo effects.
    Now I have a stereo setup with SA Ventris and Strymon timeline in a stereo loop and all gain pedals in front of the H90.
    I really love this setup which makes it possible to run the Ventris and Timeline effects in parallel with the H90.
    Might try this setup with a splitter before the H90 for a W/D/W version, but that will prevent me from having a 100% wet Leslie and similar sounds.
    So I might end up getting a ES-8 or something similar for even more flexibility.
