Home Forums Products Stompboxes H90 latency Program Change Reply To: H90 latency Program Change
#170716
    You can try changing the Spillover setting to a lower value and this may improve the time between changing Programs. You may also find that using the onboard footswitches in Select Mode will be more immediate than using your MIDI controller.
