Home › Forums › Products › Stompboxes › Preset Bypass via Hotswitch (on Pedal) › Reply To: Preset Bypass via Hotswitch (on Pedal)
April 28, 2023 at 9:25 am
#170721
There is no way to map the bypass/active state to a Hot Switch using the pedal UI, you must use H90 Control to do this.
