Home › Forums › Products › Stompboxes › H90 latency Program Change › Reply To: H90 latency Program Change
May 2, 2023 at 12:16 am
#170828
I’ve found that it cuts out when switching between programs that utilize different algorithms as well as ones which use the same one (though it seems less noticeable with the latter).
If I have the unit bypassed and then load a program using an external controller, all audio momentarily cuts out before the program loads appropriately.
