Home Forums Products Stompboxes H90 Software 1.5.2 Reply To: H90 Software 1.5.2
#170872
cestlamort
    Thanks for the confirmation. Easy enough to fix the presets, but takes a few minutes (and if you remember the env mix level – I’ll admit that was not a parameter I was using).
    It was a bit puzzling as I spent the morning dialing in some stuff and then it all sounded funny in the afternoon. I double checked against a sample of presets on my H9, and the ENV mix did change on those after the update.
