Home › Forums › Products › Stompboxes › Time Factor mono to Stereo routing › Reply To: Time Factor mono to Stereo routing
        May 3, 2023 at 12:50 pm
        #170931
Sorry, the TimeFactor will not sum the stereo inputs to a mono output when the pedal is bypassed. As a work around, you could adjust the mix value to 0 instead of bypassing the pedal, and this will preserve the mono summed signal.
