Home Forums Products Stompboxes Using H90 with Digitech FS3X Reply To: Using H90 with Digitech FS3X
#171037
joecozzi
    Hello Baccetti,
    It is possible to emulate the behavior of SELECT mode functions using an aux switch. Depending on which EXP input the switch is connected to, it will behave as 1,2,3 for EXP1 or 4,5,6 for EXP2.
    Go into the System Menu > Global > Global – Pedal Ctl
    -One switch should be mapped to “P act/byp”
    -Another switch should be mapped to “decrement”
    -A third switch mapped to “increment.”
    With these mappings you’ll be able search up and down your Playlist and activate or bypass the program.
